I recently had a customer create a global virtual channel in Measurement and Automation Explorer (MAX). They then set the maximum and minimum values for the input range of their signal.
My customer wanted to access the +2 and -2 values entered above and display them in LabVIEW. However, the property nodes for global virtual channels only accesses the limits of the board. For example, the customer's board may only be able to handle voltages between +/- 10 Volts. No matter which property node we chose... all that was returned was the +/- 10 Volt range. Could we please give customers access to this information?
