Data Acquisition Idea Exchange
GITA_A
It should be read programattically what parameters a DAQ Card supports!!
Status: New
Hi all,
Any series card should have a feature listing different  parameters like voltage, temperature etc it supports(May be a property node should be used). so that user can configure the required parameter among the supported.
Ex: SCXI -1520 module can be configured as Strain, Pressure or voltage but this information will be known only by seeing its manual or when a task is created in MAX. But in LabVIEW               Software i cant get this information directly. Because it allows me to configure 1520 as temperature also and we will come to known that 1520 module doesn't support for temperature       parameters only when once tried to acquire.
So what you people think about you.Share your ideas on this please.
geeta
