All of the JAT's VIs output results as "sequence" and "timestamp", eg. the "Max and Min Voltage.vi".
I use the JAT to analyze high speed differential signals with unit interval of just 300ps. Because of this, the timestamp output cannot meet the required resolution. However, if timestamp is replaced with double precision float, it should be able to.
I have brought this up with NI's tech support and this is what they recommend, which is to suggest this change over here.
