Many CAN protocols require a byte in a cyclic message to be incremented each time the message is sent (this is often byte 0). I might have read somewhere that this is possible with VeriStand but I am not using it. So when using only LabVIEW and the NI-XNET API, the only way to achieve this is to call the XNET Write function to manually set the value of this byte. But having to call the API each time the message should be sent removes all the benefits of cylic messages... Moreover LabVIEW can't guarantee the same level of speed and determinism (if the message is to be sent every 5ms for example).
Being able to configure a signal to be an auto-incremented counter would be a huge improvement. To me, this is a must-have, not a nice-to-have...
