Suggest NI produce an inexpensive (<$100) USB "stick" that has 2 hardware counters on it for optically isolated measurement of encoders, or other high-speed devices. The stick would have a standard connector it for easy wiring of differential encoders with ABZ lines. The device would enable measuring two separate encoders or track two sections of a shaftless drive line that needs to position-follow. One or two DIO lines would be a bonus. This would seem to be a good fit for the industrial machine markets (at the very least). Today you need to buy a multifunction daq for a several hundred dollars if you want two counters.
Contact me with any further questions.
Thank you!
Rick Yahn
QuadTech, Inc.
414-566-7938
