04-11-2014 03:06 PM
I created an application using the DRL VI library. When I create an installer, deploy it on a remote PC and try to run it, I'm prompted for imaging software DRL license activation. Do I need a license for every deployment of an app. containg this library? If not, is there an additional installer I need to include in my installer build? I looked over the list of the additional installers and did not see anything with the words Denso, Imaginglab, or digimetrix in the name.
04-15-2014 02:18 AM
Helo cjrsupertech,
Yes, you need to have a separate license for every machine (PC or NI RT-target) that uses DRL VI's and communicates with a robot (from LabVIEW and/or from an application).
DigiMetrix robotics library serves you as an additional LabVIEW toolkit. Unlike other additional LabVIEW modules and toolkits DigiMetrix libraries do not use separate Development and Run-Time licenses. Instead libraries use a different scheme where license is moving with a robot (or robots) connected to the PC or LabVIEW Real-time target, on which robot application is actually running. This PC and LabVIEW Real-time target are called PC target and RT target accordingly.
Every purchased license includes the following:
Kind regards,
Nikita.
