Digital I/O
Are DI/O cards like the 651x compatible with PCIe 1x?
This may be a bit of a stupid question, but this is my first outing with NI and yet I have somehow been given some amount of responsibility for a very strange procurement process.  Hopefully the question is simple to answer and that will mitigate its possible dumbness.
Are cards like the NI 651x (http://www.ni.com/datasheet/pdf/en/ds-105) compatible with PCIe 1x?  From the image it looks like they are designed to run on PCIe 16x, but since speed is not a major concern I was wondering if it would install and run normally on PCIe 1x.
I am limited in procurement to a default, organization wide Tower PC build, whose motherboard has two PCIe 16x and two PCIe 1x.  Since I will likely need three cards, I was hoping that it would be compatbile with the PCIe 1x slot and would save us the special procurement order form hassle.
Thanks for any help!
(3,657 Views)
Accepted by dzaks
No.  That is not even a PCIe connection.  It is PCI.  I recommend you give your local NI rep a call and discuss your requirements and they can help steer you in the right direction.
GCentral
(3,656 Views)
Trust crossrulz on this (and most things.)
http://us.ni.com/contacts has our inside sales number (877) 387-0015 and also has a list of local representatives who can assist you. I would advise you to call our inside sales number as they will be able to answer your question quickly as well as get you a quote if needed.
Alex W.
(3,631 Views)
Thanks crossrulz : )  Unfortunately I'm in Austria, and it's been a little tricky getting in touch with an NI rep, but it looks like we were able to find an old PC with PCI slots; if that doesn't work we will consider some sort of adapter/connector.  Thanks for the clarification : )
(3,549 Views)
