Digital I/O
Could not load device properly
Hi All,
I don't know what is the system change that my previous devices are no longer shows up properly, please get the working pictures and broken pictures
Struggled for this error for 2 weeks and not been able to figure out the solution.
(1,208 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MO7SAM&l=en-US
In my experience, NI MAX errors occur with certain settings of Firewalls and AntiVirus software, where it blocks NI MAX UI from contacting the database. This could have happened without your knowledge if your IT group changed some Firewall policies from the central server. I would recommend you to try the troubleshooting steps mentioned in the article in the above link.
If none works out, the only other option is to reinstall all drivers and possibly a system restore.
Santhosh
Soliton Technologies
(1,202 Views)
Thanks a lot for your reply, I have tried mostly everything, the only solution would be a clean PC re-image, but once I remove keysight IO library, this corruption happened again
I want to know what dependency result in this failure? can I somehow just repair one component or re-install some dependency?
(1,157 Views)
I highly think Keysight IO library is the culprit corrupting NI MAX, it is not simple to know which dependency is causing the trouble (at least as an user) - to get more info, you would need to raise a support request with NI Support.
The easier route will be to start from a clean slate, hold off the Keysight IO library until the last, so you can figure out if it is the one corrupting NI MAX.
Santhosh
(1,151 Views)
I installed 20.0 release of the NI Max, but our production line still would nee to use 20.5 release to control the DIO devices,
When I install 20.5 release, I always get below error:
How can I resolve this ?
(1,134 Views)
