Digital I/O
DAQmxSetDIInvertLines
Where is some example to use DAQmxSetDIInvertLines() function?
I'm converting DAQ to DAQmx..from Parkoz.com
(3,136 Views)
Hi anarkie,
You can find information about this function in the NI-DAQmx C Reference Help.  The Help is installed with DAQmx and can be found at Start >> All Programs >> National Instruments >> NI-DAQ >>Text-Based Code Support >> NI-DAQmx C Reference Help.  I searched for DAQmxSetDIInvertLine and found help for the syntax of this function and a brief description of what the function does.  I would also suggest looking at the example programs located at  Start >> All Programs >> National Instruments >> NI-DAQ >>Text-Based Code Support >>ANSI C Examples.  These examples will give you a good starting point for using DAQmx. I would take a look at the Read Dig Chan example, located in the C examples at Digital >> Read Values >> Read Dig Chan.  You will notice that at the beginning, the task and channel are created.  Once these are created, you will be able to use the DAQmxSetDIInvertLines function.  I have added an attachment modified from the Read Dig Chan that does exactly this.
Jim Schwartz
(3,110 Views)
