Digital I/O
SHC68-68-RDIO Shielded Cable for DIO connector
HI,
I need the below mentioned part no cable pinout document.
(191667-01) SHC68-68-RDIO Shielded Cable for DIO connector.
Regards
Vignesh M
(1,571 Views)
Hi
Is this that you need?
Best regards
(1,543 Views)
Thank you for your valuable support.
But actually I needed for SCSI to VHDCI wring details. In this it is showing wire mapping SCSI to PCB .
If that wire mapping document is correct means some pins are taken for two lines in SCSI connector side. ex : see SCSI 25th pin .
my question is can i able to use this cable for PXIe7821r.
I have confusion also.
Regards ,
Vignesh
(1,490 Views)
I think this article can be useful for you.
According to the link below in the ACCESSORIES you can see the compatible digital cable for PXIe-7821.
https://www.ni.com/sic/configurator/configure.action?sfId=NI&wcs_l=en-us&wcs_k=pxi-digital-reconfigu...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019QYBSA2&l=en-US
Best regards
(1,481 Views)
