01-17-2021 09:45 AM
I wish to communicate with a I2C device that uses 3V3 I2C levels. I know the USB 8451 will accept a 3V3 I2C input as a 'high' logic level, but can the USB 8451 provide a I2C output at 3V3 logic levels to the target device?
Do I need to add an external voltage level shifter IC between the USB-8451 and the target I2C device?
Solved! Go to Solution.
01-17-2021 10:14 AM
The 8451 does not have a build-in pull-up resistor. So the voltage level will depend on whatever pull-up you have on the lines. The 8451 just needs a voltage of at least 2V to register a high, with a maximum input voltage of 5.8V (but would not suggest exceeding 5.5V).
