Digital I/O
half duplex pulse pattern communication on FPGA spartan 3 in Labview
I want to transmit a pulse pattern from single pin and recieve the type or a bit different pattern just after transmission on the same line, then transmit another pattern after comparing the recieve pattern with the tarnsmitted pattern. The interval between two transmissions is 400us and frequency of pulses is 600KHz and no. of pulses in one pattern are 25.I want to know that Can this problem be solved on FPGA spartan3E with Labview?
Yous sincerely
(5,534 Views)
Hi there, consider not the FPGA but the IO capabilities...the specifications sheet from your hardware can provided you with that answer. Regarding the pulse pattern, perhaps this can help.
Alejandro C. | National Instruments
(5,498 Views)
If you want to use a DIO resource for bidirectional communication, this resource will be of use
(5,471 Views)
