Discovering and Imaging the Device
Status light flashing and cannot connect
Hi, our roborio's status light is blinking continuously and we cannot find it in the imaging tool, we have tried to flash the .zip file in balena etcher with no changes.
Thanks in advance for your help
Michael
(1,749 Views)
Hi, Space!
Can you try a different SD card?
(1,747 Views)
We tried a different SD card and the status light is still flashing continuously. Booting into safe mode by holding reset yielded no change as well, and still flashes continuously.
(1,701 Views)
Is there anything besides plugged into the roboRIO2?
Can you try the Raspberry Pi image?
https://docs.wpilib.org/en/stable/docs/software/roborio-info/roborio2-imaging.html
(1,693 Views)
Thanks! We found out that we simply flashed the wrong image, there's a folder called SD Images that we should have copied from but instead went for another zip. Fortunately the problem is solved now so this is nice!
(1,671 Views)
