cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Juego de pong con property node
I want to play a game of pong and with it when the ball does not hit the bar, leave the program.
Deseo realizar un juego de pong y con el cuando la pelota no le de la barra salga del programa.
0 kudos
Mensaje 1 de 2
1.892 Vistas
@2Lui wrote:
when the ball does not hit the bar, leave the program..
  • Is that want you want or does it currently happen but you don't want that?
  • This is not a gaming website, so I assume this is about programming, not playing.
  • Who wrote the program? can you show us some code? Explain how you interact with it, what happens, and want you want to happen instead.
0 kudos
Mensaje 2 de 2
1.878 Vistas
