cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Mediciones de corriente alterna
¡Resuelto!
Ir a solución
Hola a todos.!
Mi pregunta es: ¿Que bloque de NI DAQmx  se podría utilizar para medir corriente alterna y posteriormente potencia eléctrica?  actualmente cuento con sensores de efecto hall que envian 0-5 V  y son capaces de medir de 0-100 A, ademas del modulo NI-9239 y un compactRio.
0 kudos
Mensaje 1 de 7
3.569 Vistas
Hola gomoo,
as this is an English forum you should write English messages - or use the Spanish forum…
My question is: What block of NI DAQmx could be used to measure alternating current and then electrical power? I currently have hall effect sensors that send 0-5 V and are capable of measuring 0-100 A, in addition to the NI-9239 module and a compactRio.
Usually the cRIO devices don't support DAQmx (only some new/recent types).
Usually you use either the ScanEngine or the FPGA inside the cRIO - both is explained in the example projects coming with LabVIEW(+RT+FPGA)…
To calculate power you also need to measure the voltage in parallel to current!
Mensaje 2 de 7
3.563 Vistas
Hola gomoo,
La respuesta de GerdW esta clara?
0 kudos
Mensaje 3 de 7
3.530 Vistas
Sorry for write in  spanish..   I have  a  recent  versión of  compact RIO (cRIO-9046), and I´ve done some programs like measure  AC voltage with  NI DAQmx and NI 9242. But now  I want to measure AC Corrent, thats why im asking for  what  bock of  NI DAQmx can use for this sensors because the output is 0- 5 VCD.
Regards
0 kudos
Mensaje 4 de 7
3.465 Vistas
Solución
Aceptado por el autor del tema gomoo
Hi gomoo,
When the sensor outputs a voltage signal then you can still use the voltage reading…
(You may apply a scaling to the voltage reading to convert the values into the corresponding current values.)
Mensaje 5 de 7
3.460 Vistas
Great!,   but  I dont know  how to convert these values..
0 kudos
Mensaje 6 de 7
3.330 Vistas
Hi gomoo,
read the manual of your sensor...
0 kudos
Mensaje 7 de 7
3.309 Vistas
