Examples and IP for Software-Designed Instruments and NI FlexRIO
Run c\c++ app for NiFPGA in docker
How to run app with NiFPGA lib in docker?!
Example application in attachement - test_open_RIO.c
App build command:
g++ test_open_RIO0.c -I/opt/include -L/opt/lib -lNiFpga -o test_open_RIO0
Host App(./test_open_RIO0) output:
Hello, wrld!
Ready: 1
DIO0: 1
NiFpga_True 1
Finished
Host lsrio.py output:
RIO0
--Model Name: NI 9159
docker build command:
docker build --rm -t startrio .
docker run command:
docker run --rm --privileged --device /dev/RIO0 --mount type=bind,source=/sys/devices/pci0000\:00/0000\:00\:1c.5/0000\:02\:00.0/0000\:03\:03.0/0000\:04\:00.0/0000\:05\:01.0/0000\:06\:00.0/0000\:07\:08.0,target=/sys/devices/pci0000\:00/0000\:00\:1c.5/0000\:02\:00.0/0000\:03\:03.0/0000\:04\:00.0/0000\:05\:01.0/0000\:06\:00.0/0000\:07\:08.0 -it startrio bash
I have added host dev RIO0 to container and mounted PCI dev.
Now we are in conteiner bash!
conteiner lsrio.py output:
RIO0
conteiner App(./test_open_RIO0) output:
Hello, wrld!
Open error: -63192
Finished
On host FPGA device is accessible, from container is not accessible.
Sig
Comments
alqio
Member
Member
on
Did you figure this out? We are facing the same problem.
nips180486
Member
Member
on
no
Sig
