FIRST Robotics Competition Discussions
CRio not retaining Robot Code
We are having a problem with the Robot code. After deploying the code, the system works but after we turn off the Robot power supply and restart it, the driver station indicates NO ROBOT CODE. Need assistance.
(4,429 Views)
Did you right-click on the cRIO target and choose "run as startup" ?
Geoff Schmit
Huskie Robotics, FIRST Team 3061 Lead Mentor
http://team3061.org/
@team3061
(3,122 Views)
Also make sure the cRIO switch is set to the correct setting which will allow the code to boot up during startup.
Bill
(3,122 Views)
