02-02-2010 04:59 PM
Subject tells all basiclly when the camera is pluged into the crio the connectivity lights do not light up
Do I have to flash the crio with something?
02-02-2010 07:46 PM
Are you using an Ethernet crossover cable?
Geoff Schmit
Team 3061
Naperville North High School
02-02-2010 09:18 PM
The camera is connected to ethernet port number two on the crio and the bridge connects to the first ethernet port.
02-02-2010 09:46 PM
That's good, but what type of Ethernet cable are you using? If you connect the camera to the cRIO with a standard Ethernet cable the link light won't be illuminated on the cRIO. You need to connect the camera to the cRIO with a crossover Ethernet cable.
02-02-2010 09:53 PM
Oh ok thats...Didn't realize there was a difference. Now I get it ill see if we can find one.
02-03-2010 04:55 PM
So a person on our team said he could make one but, on the wikipedia site there diagrams of multi kinds of cross over cables what one exactley do we need?
02-03-2010 05:05 PM
Hi Jeramy,
Use the 10/100 configuration (the first one in the Wikipedia article). You should also have an orange crossover cable in the kit.
Good Luck!
Kyle
FIRST Applications Engineer
