FIRST Robotics Competition Discussions
Classmate display resolution and Drivers Station Program
Our Classmate resolution changed to 640x480 and when we reboot we cannot exit the drivers station by
clicking the Exit button in the Setup screen. Tried to hit f8 on bootup, but the system just goes straight to the
drivers station logon.
Is there a key sequence or other method to exit the classmate drivers station user login and go back to
the developer login to change the displayresolution?
Eric
(4,478 Views)
If you hold shift while you are booting up, it should bypass the auto-login and let you log into the developer account.
(2,757 Views)
Thank you, that worked...
Eric
(2,757 Views)
