02-22-2010 07:46 PM
When I try to build the code to be downloaded into the cRio (to be run at start up) I get the error listed below. I went back to an older version that had been build and deployed, that got the same error. Since I didn't even realize I was using a "AB_Build.lvclass".
My question, what is the AB_Build class?
What objects are built from it in the Robot project?
What could be the problem or what I can look at to fix this?
ERROR TEXT:
An error occurred while saving the following file:
C:\Documents and Settings\Joe\My Documents\LabVIEW Data\2010 Game Robot Project_02_20_10\Robot Main.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
<APPEND>
Method Name: <b>Save:Target Instrument</b>
02-23-2010 09:32 AM
I'm wondering if you are trying to build code you originally developed using last year's template? If so, look in your autonomous code to see if you have a constant Boolean (T/F) wired to a case structure. If you do, replace the constant with a control, and then try to build your code.
02-23-2010 10:33 AM
I'm using this years template but we usually have expirimental code with a t/f constant wired, depending on who's trying something. I'll see if that fixes it when I get back to the crio.
Thanks!
02-23-2010 12:38 PM
That worked! thanks!
