FIRST Robotics Competition Discussions
cRIO FRC II not working: over volted
I am with FRC team 4499.
One of our cRIO FRC II's was damaged when the powersupply it was connected to broke. After disconnecting the cRIO, I measured the output voltage on the powersupply: It was outputting approximately 50 V. The resistance between the cRIO power pins has dropped to approximately 2 ohms. None of the LEDs lit up when it was reconnected to a functional power supply.
Is there any easy way to repair this, or would it be best to return it and ask for a replacement?
(3,646 Views)
This sounds like something you will need to return and ask for replacement.  I think this is the correct number to call for replacement:call (866) 511-6285 from 1 p.m. to 7 p.m. CST, M-F
Kevin Fort
Principal Software Engineer
NI
(2,833 Views)
