Feedback on NI Community
Text after images (hard!)
If we insert an image at the end of a post, it is impossible to add new text after the image if we are in "rich text" mode. As a workaround, we need to switch to HTML and type at least one character after the image before going back to "rich text" mode and finish the sentence.
This should be easier.
(chrome on windows 10. I have not tried other browsers)
Message 1 of 13
(4,083 Views)
Hi Christian,
Can you please provide more steps to help us reproduce the issue you are facing? If I insert an image to a post (no specific alignment chosen), then hit the Enter key, I am taken to the next line in the editor and can begin to type text with no problem.
Lili
Message 2 of 13
(4,067 Views)
Try with an image that is wider than the edit window and thus gets scaled down during the insert.
Message 3 of 13
(4,051 Views)
I tried again with a 1920 pixel wide image and was able to insert text after the image.
Is there a particular image that is causing issues? Or what is the width of it so I can replicate it?
Lili
Message 4 of 13
(4,047 Views)
Well, sometimes it work, sometimes it does not. I'll do some more test....
Message 5 of 13
(4,043 Views)
Still struggling with this on a daily basis. Most of the time I cannot place the text insert point if the last item is an image and I want to type below it.
Message 6 of 13
(3,677 Views)
Sorry to hear this is still an issue. If you could provide a video or steps to reproduce, this could help with figuring out the problem.
Message 7 of 13
(3,673 Views)
Well, maybe I am the only one in the world doing it wrong, but whenever an image is the last object in the edit box, most of the time I cannot click to place the insert point after it. I can click below the image (difficult, because there is no space) or to the lower right of the image. and hit enter or start typing, but nothing gets added to the post.
Message 8 of 13
(3,663 Views)
I have seen this before.  I just got in the habit (a long time ago) of hitting enter twice and then go back up to the first one to insert the image.  I then still had an empty line to add to the post.
GCentral
Message 9 of 13
(3,658 Views)
I think I see what you mean now. However, I don't think you are meant to be able to click under the image, if it is the last thing in the post. For instance, if there were only text in the post, you can't click a line or two below it and start typing. You have to hit enter first to go to the next line.
Message 10 of 13
(3,646 Views)
