Feedback on NI Community
Text after images (hard!)
My typical workflow is to type ... insert image ... type some more after it ... insert another image ...type some more after it. I regularly get stuck after each image, hampering my workflow. 😉
Yes, if I remember (!!), I can add a few linefeeds and go up a few lines before inserting each image. However, often I forget until it is too late 😞
Switching to HTML view can act as a workaround as described, it is just not ideal. 😄
Message 11 of 13
(557 Views)
Hi Christian,
I stumble across that problem too.
Workaround:
As I can write to the right of the image I just write the next words, then insert the line break between image and text…
Message 12 of 13
(532 Views)
Just confirming this often (always? not sure) affects me too - I usually have to remember to type some nonsense, then scroll up to insert the image.
If I forgot to do this, I typically find it easier to copy what I have and cancel posting and retry. Good to know that switching to html and adding there will allow me to continue...
GCentral
Message 13 of 13
(509 Views)
