If I put an array on the front panel and only want to show the values starting at for example, 3, choosing "set as default" for the array indices when 3 is the first index does not work. When I run the WebVI, it still always shows index 0 first. In LabVIEW you can use "set as default" to set the displayed index values but not in G Web it seems. Am I missing something? Is this expected behavior?
