G#
Error 1326 with G# 1.7.0.4
When G# is installed, I get the foolowing error when I click on a folder in my project (LV2017 64 bit) :
 Any idea ?
Thank you
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn |
Stop writing your LabVIEW code documentation, use Antidoc!
(7,475 Views)
There seems to be an issue with the vipm-installation. Until it's fixed i recommend downloading the zipped installation from our web page.
http://www.addq.se/test-och-matsystem/free-tools/
/Y
Qestit Systems
Certified-LabVIEW-Developer
(7,465 Views)
Accepted by topic author Olivier-JOURDAN
I can confirm what you see. However, this behaviour does not exist if installing from the downloadable zip-file, so if you want to update G# I suggest you use this link to download it from instead: http://www.addq.se/test-och-matsystem/free-tools/
The error message you are seeing will not affect anything and only happens the first time you right-click on the folder, so you are still safe to use 1.7.0.4 if you can live with the small annoyance.
This will be fixed in the next release, but I cannot say when that will be.
The reason to why the VIPM is different from the zip-file is that to create the VIPM-package for a plugin that hooks into the project explorer, there are a number of manual steps that need to be made in a process that is not fail-safe, and my guess is that one VI was added with an incorrect version. I am hoping we can replace the VIPM distribution with the new NI-package manager for versions in the near future...
Certified LabVIEW Architect
(7,456 Views)
Thank you for the feedback and the fix.
Have a good day.
Olivier Jourdan
(7,445 Views)
