09-20-2006 01:07 PM
09-20-2006 05:04 PM
09-20-2006 05:49 PM
09-20-2006 06:04 PM
Hi Dan,
You might want to take a look at the niScope EX Multi Record Fetch More Than Available Memory.vi shipping example. With this VI you can set up a multirecord acquisition and fetch records as they are being acquired. This allows you to acquire more records than will fit in the onboard memory. Currently, there are limitations in the driver which limit you to fetching about 2,000 to 3,000 records per second, so you will not be able to keep up with your 10 to 20 kHz trigger signal indefinitely. However, we are currently working on fetching optimizations which should bring this number up to the 10 kHz range in the future. We hope to release these optimizations in Q1 of 2007.
I hope this helps.
Sean Close
