High-Speed Digitizers
Display in frequency domain
Is it possible to display data in frequency domain instead of time domain for NI-Scope soft front panel?
George Zou
(7,586 Views)
Zou,
The Scope Soft front panel is for time-domain display only. You could not use it for Frequency Domain simply because you require some processing to display data in the frequency domain.
Ayman K
(7,577 Views)
While you cannot currently display frequency domain data in the NI-SCOPE Soft Front Panel, you can get some useful scalar information.  Try CTRL-M, which will bring up the Measurements Window.  You can add measurements like Frequency, Average Frequency, and FFT Frequency (these will be a single, scalar value rather than a spectrum).
NI Signal Express provides simple ways to see frequency domain data in an interactive environment.
If you are a LabVIEW user, you can use the NI-Scope Express Block and the Spectral Measurements Express Block to configure the digitizer and display frequency domain data in two interactive steps.
If you are a C/C++, CVI, LabVIEW, or Visual Basic user, the NI-SCOPE driver provides programmatic access to frequency domain data (and much more) through the built-in Measurement Library.  Using Fetch Array Measurements, you can get an array of data representing the FFT Amplitude or Phase spectrum.  See the following examples for a demonstration:
   niScope EX Advanced Measurement Library.vi (LabVIEW)
   AdvancedMeasurementLibrary.prj (LabWindows/CVI)
   MeasurementLibrary.c (C)
   AdvancedMeasurementLibrary.frm (Visual Basic)
(7,570 Views)
Hi, I have been reading this post It is very interesting and also I need help. I am doing a project involving scattering matrix (S parameter) using frequency and time domain analysis. In order to make use of S parameter in frequency domain from Vector Network Analyzer, I need to convert S parameters from frequency domain (sweep from 8.2 GHz to 12.4 GHz) to time domain using inverse chirp z transform or any. I have no idea how to implement it. Could you please help or guide me how to implement them. I am using Labview 8.0 and matlab. Please see the attached file for the data in frequency domain both linear , dB magnitude and phase.
Thank you so much for any help.
Tantong
(7,209 Views)
You have posted the same question in numerous different threads and different forums. Stop it. Now.
(7,202 Views)
Sorry, I won't do that again. I just try to get some advice from different group.
(7,198 Views)
