High-Speed Digitizers
NI PCI 5102 installation issues
 I purchased a NI PCI5102 Digitizer card on  and am currently trying to install it on a windows XP computer.
The Measurement and Automation explorer detects the device and it shows up under "traditional NI-DAQ (Legacy) Devices as the NI 5102, but it is unable to detect the serial number or run any test panels.  I checked the card in another computer but it works fine.  I have upgraded the Measurement and Automation Explorer on this machine with no luck, what should I try next?
Message 1 of 17
(8,390 Views)
Hello Jebeyers,
What version of NI-Scope are you using?  (MAX >> Software Tab >> NI-Scope)  The newest version of NI-Scope is 3.3.2.  I would recommend repairing your current driver or downloading and installing the newest version.  The NI-5102 should be present under Traditional NI-DAQ and you should be able to detect the serial number and use test panels.  The fact that you are unable to do these functions, it seems that the driver is corrupted.
Respectfully,
Rob F
Test Engineer
Condition Measurements
Message 2 of 17
(8,364 Views)
NI Scope 3.4 is the newest version available
http://joule.ni.com/nidu/cds/view/p/id/917/lang/en
Message 3 of 17
(8,358 Views)
 I uninstalled the existing NISCOPE application and attempted to reinstall SCOPE 3.4.
When I start the SCOPE soft panel, it still reads as version 2.8.  Is there other applications that I must uninstall besides the scope front panel before upgrading?
Message 4 of 17
(8,353 Views)
The versions of NI-Scope and NI-Scope Soft Front Panel (SFP) are not set up to be the same.  The installation of NI-Scope version 3.4  includes version 2.8 of the Soft Front Panel.  You do not need to uninstall any components.
Did installing the new driver fix the previous problem you had with running the test panels?
Message 5 of 17
(8,337 Views)
The problem still exists with the new driver.
Message 6 of 17
(8,327 Views)
When you try to run the test panel do you get any error codes in the "Last Error" indicator or does the test panel not open at all?
Message Edited by Matt E. on 01-28-2008 11:08 AM
Message 7 of 17
(8,320 Views)
When I open the Measurement and Automation Explorer the device is listed, but the serial number is blank.
If I attempt to run the Test Panel, I get a pop up stating "The device did not pass the test.  Would you like to continue anyway?"
If I click yes, the Last Error field has a zero.
Message 8 of 17
(8,313 Views)
It sounds like your board is not even passing self test which is just a very basic check to make sure the driver can read and write to the board.  The fact that windows is recognizing the board and that the board works fine in another computer definitely makes this sound like a driver problem.  I hate to make you do this again but I think we should take one more crack at reinstalling some drivers.  This time lets uninstall things first the make sure you get a clean install.  Go to the control panel and choose "Add or Remove Programs", then find "National Instruments Software" in the list and click "Change/Remove".
Select the following software items from the list that pops up and click the remove button:
"NI-DAQmx", "Traditional NI-DAQ (Legacy)", "NI-VISA" and "NI-SCOPE"
Once the uninstall is complete restart then reinstall NI_SCOPE 3.4, this should automatically reinstall the DAQ and VISA software for you.
Let me know how this works out, if this does not fix the problem then there may be some sort of problem in communication between your PC and the 5102 and we will need to get more specific information about the computer you ae using to debug it further.
-Matt
Message 9 of 17
(8,308 Views)
I unsintalled ALL NI software (CVI/Labview/RT/MAX and everthing else)  restarted the computer and of course windows could not find the driver.  I reinstalled SCOPE 3.4 which reinstalled MAX, VISA, etc.
The problem still exsists.  The computer is an HP/Compaq DX2200.  The only PCI cards are the PCI5102 and an ethernet cards.  I have already removed the ethernet card and swapped PCI slots.
Message 10 of 17
(8,291 Views)
