High-Speed Digitizers
Real Time Module needed for hi speed digitizer PCI 5911 ?
Rookie question :
I run LV 7.1 , LV Run Time  8 ( whatever this Run Time Engine may be ) , MAX  4.0.0 , NiDaq 8 ( for my two Multi Function PCI Daq's ).
Question : does the PCI 5911 work under NI-Scope 3.3 ( supporting PCI 5911 ) without a Real Time Module ?
i.e. is the Real Time Module a separate ( hardware ? ) device, not necessarily needed for PCI 5911 ?
Sorry for this utter basic question.
I have not used a hi speed digitizer before, only multifunction NiDaq's.
Thanks for any help or reference.
(6,639 Views)
You are probably referring to the LabVIEW Real-Time Module described here.
This is an extension to LabVIEW that allows you to run VIs on a real-time, deterministic environment, usually on remote hardware.  One common configuration is to use a Windows system as your host, and communicate to a remote PXI controller running LabVIEW RT.
The PCI-5911 is fully supported for "standard" LabVIEW running on Windows.  You don't need LabVIEW RT to use it.
In fact, the PCI-5911 is not supported under LabVIEW RT.
Message Edited by psisterhen on 10-16-2007 09:50 AM
(6,625 Views)
OK.
Thanks, this helps.
Peter.
(6,615 Views)
