How do I get two traces spaced apart on a graph when using a 5102 digitiser, I have tried adjusting each off set but the traces just disapear from the graph.
Is there something I need to set?
Any ideas
Also I am reading values from the graph using a couple of cursors, this works great for a constant signal from the digitiser, but when it is a single pulse the display disapears when the timeout expires.
How can I get it to stay on the the display so I can move the cursors to display the values, also the cursors values don't change when there is no trace, they stay on the last value.
Allan
