[IDLE] தமிழினி
Data Transfer between Asynchronous VI and teststand Sequence
I am working on a project where I need to display progress bar at operator level interface which is running asynchronously. Using the SequenceFilePostStep, I managed to post UI message for the Progress bar in Percent. But now I need to receive the UI message in the asynchronous VI which is running in seperate thread. Previously I used Get UI Message method from Sequence Context Engine but that doesen't help. Also tried Teststand  Queues and Notifiers. Any help will be appreciated.
Thanks in Advance....
(2,306 Views)
Hello @ராஜ்(Raj) ,
Please check the below option,
Invoke a method (VI) for TestStand UI MessagesInvoke a method (VI) for TestStand UI Messages
(2,279 Views)
