Hi Jerry Sir,
Thanks for your good information.
1.For testing i used this parameters value.
Text-'sree',fc=8.6MHz,Fb=19200 and Transmit frequency is zero,why because already i up converted in math script node.
2.Yes you are correct sir.Sorry sir i didn't observed that thing.Here i am getting imaginary values are zero.Here for generating modulated signal i am using Math script node.Here i am generated signal correctly,but in converting into complex signal i did a mistake.I am trying to rectifying this one sir.You can also suggest correct way.I need to generate 6 modulation schemes are 2-FSK,4-FSK,BPSK,QPSK,OOK and GMSK.I tried to use Modulation toolkit but in that OOK and GMSK are not there,that too i am unable to generate my own bit stream.
3.Here i am attaching phase changes snaps.i told you sir i am using NI 5640R IQ example project,in that not mention about memory size block, i thought default vales is 20k.I tried with 8k samples(I and Q sample pair),even though i am getting phase changes.I tried with NI 5640R analog input and output example project also,in that also same problem.
I told you sir,if it is sine wave i am not getting phase changes,that too when if i adjust wave form size to some fixed size like 7500,9000,10000,12000 Etc,
if it is 10001,12350 etc i am getting phase changes.For modulated signal i am unable to adjust that length,because it is depending upon Fc,Fs,Fb Etc.Eevn though if i adjust same as sine wave lengths i am getting same phase changes.
Here i am attaching two more VI.U try with this also and correct me.
i."test_sin.VI" you test with Fc-8.6MHz,Transmit frequency is zero and in mathscript node Tb=0:ts:0.0003-no phase changes,Tb=0:ts:0.0004-phase changes are occurring.
ii."twofsk_mod_mtool(HOST)" in this i am unable to generate my own bit stream.
Here also i am phasing that same problem imaginary values are became zero.
I didn't get why,here i am not doing any data type conversion.
Please a look into this also.
test conditions:samples per symbol-1400,fc=8.6MHz,Fb=19200,Fd=200khz and text-'sree'.
Thanking you so much sir.
Thanks & regards
Sreenivasulu.O
Cell: +91-93948-22850
