Industrial Communications
Kunbus Configurator III Profibus - Modify module start address
Hi all,
I'm trying to configure a Profibus network between a Comsoft DF Profi II PXI card as a master, and a Siemens S7-300 PLC (CPU 315-2 PN/DP) as a slave.
Downloaded the CPU GSD files from the  Siemens website and installed it in Configurator III - all ok
Comsoft DF Profi II PXI card ok in MAX  and was able to download/flash a dummy Profibus configuration/project using Configurator III.
In the PLC the Profibus signals are mapped from address 100 onwards.
For the example below I would like to define a 2 byte output module with the start address 100.
However the start address is greyed out.
Q: Is there any way to change the start address for a input or output module? For this example the only way I can seem to get to 100 is by adding "padding"  modules.
(I remember I was able to do this with Sycon/Hilscher, i.e. change the start address)
Thanks!
(1,340 Views)
hi dear Eng. I'm trying for Siemens plcs in kunbus3 and added gsdml in this tree but my device not set to plc, it's show a just empty block and no thing in hardware selection menu,can you give me that way  for create and set plc in kunbus?thank you
@Daniel.Cazacu wrote:
Hi all,
Thanks!
(353 Views)
