Industrial Communications
Rest API - Patch implementation in labview
Hello Labview'ns
I am trying to update test datas to a database via Rest API . I am able to execute Get, post functionality well. Recently got a requirement to update certain blocks via patch.
Could some one help me here to implement patch using LabVIEW?
If someone already implemented the same , expecting some hints .
Regards
(3,492 Views)
Looks like it's not supported.  Under the hood, NI uses a curl library, so you'll probably just have to implement a solution that calls curl from the cmd line.  I'm about to do the same.  Annoying that they don't break out all the methods.
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-PATCH-verb-for-HTTP-requests/idi-p/3745891
(3,350 Views)
Accepted by topic author NI_Follower
This is implemented in LabVIEW NXG. I have converted it for Labview 2020 and its working fine.
(3,241 Views)
Ah.  I haven't even looked at NXG.
Doing a quick search, it doesn't look like it's possible to convert it.  Can you point me to a page that instructs how to convert, or share the library you converted if it's not too much trouble?
(3,217 Views)
