CP210x UART Bridge and VISA
Have you checked this out?
http://digital.ni.com/public.nsf/allkb/171D2D70CFB66E74862571390062D12B
Eric Wang
Applications Engineering
Message 11 of 23
(2,435 Views)
If use PuTTY (Serial loopback test) data is transmitted.
In NI-VISA i can not run serial loopback test because viOpen not work.
viOpen() error: 0xbfff0000
status = viOpen(defaultRM, "ASRL5::INSTR", VI_NULL, VI_NULL, &instr);
if (status < VI_SUCCESS) {
		printf("viOpen() error: 0x%x\n", status);
		viClose(instr);
Message 12 of 23
(2,427 Views)
Are there any other hardware modules that you have not mentioned previously?
Eric Wang
Message 13 of 23
(2,401 Views)
Also, connect RXI and TX0 with your 6 pin serial converter. Then run a serial loopback test in MAX and/or LabVIEW.
http://www.ni.com/tutorial/3450/en/
Eric Wang
Message 14 of 23
(2,397 Views)
I have not installed the MAX and Labview. For normal operation of the NI-VISA, they are (MAX, Labview) required ?
Message 15 of 23
(2,391 Views)
cp210x and  pl2303 do not works.
ftdi work well.
Important for me to work the cp210x.
Message 16 of 23
(2,390 Views)
In NI-VISA Configuration -> State of the Device -> Busy
(old state - Uncertain)
Message 17 of 23
(2,375 Views)
Hi Nisun,
What is your complete hardware setup? I feel like I am missing a couople pieces here
Eric Wang
Message 18 of 23
(2,369 Views)
In linux
[root@localhost ~]# stty -a -F /dev/ttyUSB0
speed 9600 baud; rows 0; columns 0; line = 0;
intr = <undef>; quit = <undef>; erase = <undef>; kill = <undef>; eof = <undef>;
eol = <undef>; eol2 = <undef>; swtch = <undef>; start = ^Q; stop = ^S;
susp = <undef>; rprnt = <undef>; werase = <undef>; lnext = <undef>;
flush = <undef>; min = 0; time = 0;
-parenb -parodd cs8 -hupcl -cstopb cread clocal -crtscts
-ignbrk -brkint -ignpar parmrk inpck -istrip -inlcr -igncr -icrnl -ixon -ixoff
-iuclc -ixany -imaxbel -iutf8
-opost -olcuc -ocrnl -onlcr -onocr -onlret -ofill -ofdel nl0 cr0 tab0 bs0 vt0 ff0
-isig -icanon -iexten -echo -echoe -echok -echonl -noflsh -xcase -tostop -echoprt
-echoctl -echoke
then
[root@localhost ~]# chmod 666 /dev/ttyUSB0
[root@localhost ~]# ln -s /dev/ttyUSB0 /dev/ttyS4
[root@localhost ~]# ls /dev/ttyS4
/dev/ttyS4
In Ni-visa
Message 19 of 23
(2,361 Views)
http://megaeshop.pk/cp2102-6pin-module-usb-2-0-to-ttl-on-stc-for-arduino-pro-mini-download-better-us...
for serial loopback test use two mode
1. connect RXD to TXD
2, connect  RTS to CTS, DTR to DSR, RXD to TXD. (shown RS232Female.gif)
Message 20 of 23
(2,344 Views)
