Connecting a radio transceiver
I am working on a project where I have to connect a Connexlinx 4790 transceiver between two computers and trasnceive basic files and inforamation. I am new to labview. Can anyone help me with a VI that I can use for this project. Thank you.
(2,855 Views)
Since you are new to LabVIEW you should start with the free video tutorials.  http://www.ni.com/academic/students/learnlabview/
(2,854 Views)
The first thing I suggest you do is go through some of the things in the link nyc has posted. seccondly have you a labview driver set for your device. This API would be needed for communication over the device. If this does not exist you can create it your self but I warn this is not for the faint hearted.
http://zone.ni.com/reference/en-XX/help/371361H-01/lvdialog/idproject/
Thirdly are you aware of the steps involved in a comms system. There is alot of work involved in changing your data to binary and then modulation the signal for transmission. I suggest you look into exactly what you want to do and then come back when you have more specific questions.
Matthew Trott
National Instruments UK
www.ni.com/ask
(2,834 Views)
