Could not get NI-MAX to see GPIB device
Initially NI-MAX would not see a Keithley DMM connected to a GPIB card installed in a PCI slot in this computer. In order to get a GPIB card made by HP-Agilent-Keysight to work, I downloaded "Agilent IO Connection Expert" version 16.3. This software immediately found the instrument that is connected to it when I hit "Add an instrument".  Still NI-MAX could not see the instrument, but I read from one of your posts that you have to enable NIVISA Tulip.dll. I found in NI-MAX under NI-VISA 15.0, General Settings -> Passports, an unchecked box for NiVisaTulip.dll so I checked it.  After that I opened the Agilent Connection Expert, went to Tools -> Agilent 488 -> Agilent 488 Options tab, and tried to check the box "Enable Agilent GPIB cards for 488 programs". It came back with the message "Connection Expert could not enable Agilent 488 because a file is in use. Reboot you PC and try again."          Rebooting and trying again had no effect.  So what am I missing here?  Are there some other settings in NI-MAX that I need to make?
(4,594 Views)
Paul, it's not really clear from what you said if you actually looked back in MAX and it is not showing up there, or if it's not showing up in Agilent Connection Expert that you installed.  Have you looked through this NI KB:   http://digital.ni.com/public.nsf/allkb/3B3626D9C1F999218625694200791AD7 ?
(4,566 Views)
It turns out the problem has more to do with Agilent Connection Expert and why it keeps giving that error when I attempt to check the box to allow other programs to use the Agilent GPIB device.  This morning when I opened NI-MAX and found under Devices and Interfaces » Miscellaneous VISA Resources, my GPIB card. I verified that I was able to talk to it and from there everything worked. Thank you for your help.
(4,538 Views)
Glad everything's working in LabVIEW for you now!
(4,528 Views)
