I have a custom h/w which reads the data from GPS Rx and after parsing send it to PC over RS232.
Each second it sends 201 bytes to PC. I have developed a VI to read the GPS data and display it. Project file is attached.
Fulctionality of different loops are as following:
1. LOOP 1: 1.1 Reads the serial data from com port.
1.2 Synclonize the frame using start bytes "a" and "z".
1.3 Reads next 4 bytes containg receiving error information.
1.4 Reads next 195 bytes. in which initial 80 byes are GPS data. rest are others.
2. LOOP 2: 2.1 Extarcts the GPS information and put them in an array.
2.2 Extarcts the receive error infor and counts the total error by incrimenting the variable using shift reg.
3. LOOP 3:3: 3.1 Displays the GPS data in chart and log the data in a file.
4. FLOW : Uses the GMAP .NET based API to creat a MAP and display.
Problem statement:
1. Functionality acheived.
2. However in between data set is being missed by the programm.
Quesitions:
1. Is the developed VI is efficient in terms of using queue loacl variables etc.
2. What are the improvments I can do to solve the problem.
Any other suggestions|
Thank you
jayant
jayant
