Help to fix the repeated angle problem(SMC100 & PR50CC )
This is the example from the user library of the vendor. You see they don't have the move absolute function however I include it because I want to be able to start from any porsition then continue with the step size. I contacted the vendor they told me the structure is completely fine so I suspect the problem lie in the way I connect the subvi. This is the manual with the driver description.
You see he
Message 11 of 12
(664 Views)
Hi Dennis Knutson,
I found something now I am using highlight execution and I see the data flow trough and the data recorded increment there is no repeated data. I tried to put delay . When I use the hightlight execution it increment but when I put delay the repeated data will be in the array. any ideal how to solve?
Message 12 of 12
(659 Views)
