01-28-2016 08:42 PM
hi,
i have problem about read input register. i made program labview to monitoring Counter ( made by Autonics ),
my problem is when the counter is counting over 65534, suddenly on my program read 65535 = 1
for example
Autonics display | Labview display
65535 | 1
65536 | 2
65537 | 3
65538 | 4
etc
is that the maximum read input register ? or its a bug from modbus library ? i`ve changed the representation v16 to v64
any solution ? please help me to read input register over 65535
thanks
01-29-2016 01:21 AM
01-29-2016 01:37 AM
Through the ModBus protocol you can access 16bits registers. Not 8 , not 32 just 16 bits.
01-29-2016 04:28 AM
The Modbus standard is 16 bits. So from a single register, 65535 is the highest you will be able to read. If the counter uses a second register, you will need to read it as well and then use Join Number to make a 32 bit number. If not, then you will need to keep track of the rollover and add 65536 to your number (I would expect 65536 = 0 in the register).
