How to synchronize the number of samples of the motor position and DAQ values
If you could show that data was being lost when you built the array, I would be very suprised.
Super easy test would be to replace the Current Position output with the iteratation count of the while loop.  I'm betting that the TDMS iterates up one at a time.  Can you benchmark the time it takes to execute the Move Absolute and the Tell Current Postion parts of the code with the DAQmx calls disabled?
Justin Parker
Product Support Engineer
Message 11 of 27
(1,402 Views)
Ok Justin_P , thank you again for reply,
The equipments are in the university's lab. i will do what you asked me to do toworrow.
Kind Regards and Best wishes.
Message 12 of 27
(1,386 Views)
Dear Justin_P,
I replaced the Current Position output with the iteratation count of the while loop as you said. And when i open the tdms excel file, it is still 4 samples per second.
I also benchmarked the time it takes to execute the Move Absolute and the Tell Current Postion parts of the code with the DAQmx calls disabled. I still get 4 samples per second from the motor position. But i used the "initialize array" function both of them.
So is that mean it is true that while using initializing array.vi function some data are being lost or "initializing array.vi" decreases the samples which are taken per second??
If it is true then how can i turn an element type of wire to a 1-D array type of wire except using "initializing array.vi" , because to connect an item to "TDMS Write" , the item should be "1-D array" type of wire.
Kind Regards From Turkey.
Message 13 of 27
(1,370 Views)
You can simply use a build array but the initialize array will not lose samples or slow the loop. To truly get an idea of the mac sample rate, eliminate the tdms write. Use tick count and a shift register to show elapsed time. I suspect you have a hardware limitation that has nothing to do with the code. You have already been told this.
Message 14 of 27
(1,362 Views)
Dear Dennis_Knutson,
As you can see from the "PrintScreenLoopTime" attachment above, the loop iteration is arranged for 1ms (which means 1000 samples per sec.) then could you please tell me that  why i am still reading 4 samples per sec. although i connect a constant(loop's wait.vi's constant) not the hardware's output.
*I also used "build array" and result is the same(4 samples per sec.)
Thanks for your consideration.
Kind Regards.
Message 15 of 27
(1,358 Views)
You can set the time delay to whatever you want but if the hardware requires more time, you just cannot force it to run faster. A hardware limitation is exactly that. Talk to the vendor about it.
Message 16 of 27
(1,350 Views)
Dear all,
If we suppose that Motor Controller has this limited communication speed then:
I am communicating with the motor controller with USB cable which is also connected to a RS-232 cable . Is it possible that this converting to USB causing slower communication?
Kind Regards from Turkey.
Message 17 of 27
(1,335 Views)
No.
USB is way more faster than serial.
Please do the test without daq and see what the fastest speed of the smc is.
We have several of these instruments and have accepted that this is about the speed that is possible.
greetings from the Netherlands
Message 18 of 27
(1,331 Views)
Dear Albert.Geven,
here the pic. : I already did WithoutDAQmx involved, Still the TDMS writes "current position data"  4 samples per sec. But the real question is when i connect an another element wire(constant) to the TDMS file(after converting to 1-D array) , it is also writes 4 samples per sec.
Thank you,
Kind Wishes from Turkey.
Message 19 of 27
(1,330 Views)
Are you saying that you eliminate the code for the motor controller and just have tdms write, that you only get 4 iterations per second? I find that very hard to believe.
Message 20 of 27
(1,324 Views)
