04-23-2012 10:32 AM
Yes Dennis_Knutson,
I am saying exactly that. As you see from here i connected the loop's iteration constant to the TDMS file, and i read "1"(loop iteration constant) , 4 times per second.
Thank you for your consideration.
Best regards.
04-23-2012 10:39 AM
That link does not show anything of the sort. That link shows a VI with a DAQmx function and the motor controller read. Nor does that link show the iteration terminal connected to anything at all.
I have no idea what you have actually done. If you are going to make references to modified VIs, post the VI or at least an image of it.
04-23-2012 10:52 AM - edited 04-23-2012 10:53 AM
Dear Dennis_Knutson;
there is loop iteration constant at the right bottom side of the picture. (next to the loop's stop button). This constant is connected to the TDMS after "initialize array" function.
04-23-2012 11:21 AM
So what. What do you think that is supposed to prove? All I can tell is that I seem to be wasting time on understanding experiments of yours that do not do anything at all.
04-23-2012 11:36 AM
Hi Kindly Wisher,
Are you trying to test what I said "Super easy test would be to replace the Current Position output with the iteratation count of the while loop. I'm betting that the TDMS iterates up one at a time. "
If so, I think you are mistaking what I meant by the iteration count.
That's what I wanted wired in, not the "1" constant. The point was to show you that you weren't losing data and that the file would have "0,1,2,3,4,5..." in it.
Does that make it more clear?
04-23-2012 12:39 PM
04-24-2012 04:38 AM
Dear Justin_P,
Yes i misunderstood what you had said me before. I am sorry about that.
Thank you all for your answers. Then it is clear that the SMC100 is a slow communicator.
Kind regards from Turkey.
