How to transfer data using TCP/IP and UDP with IPv6 protocol in labVIEW
Hi
I am working on a project where I have a need to communicate custom hardware using TCP/IP & UDP IPv6 protocol.
If any one have any idea about how to communicate custom hardware using TCP/IP & UDP IPv6 protocol. I have done with IPv4 but my customer require using IPv6.
If any one have work on it please help me to get the solution.
Thanks in advance.
(4,989 Views)
I saw this link before maybe it could be helpful
https://lavag.org/files/file/67-tcp-ipv6-tools-for-labview/
(4,985 Views)
Hi Hatef,
Thanks for your support.
The link you share is very useful but in that UDP part is missing.
Do you have any vi or document for UDP IPv6.
(4,956 Views)
I think it is better to use dll for UDP IPv6 and call it in labview there i could not fund any method to use it in labview just that
(4,947 Views)
Ok..Thanks alot, I will try to get help from networking expert
(4,934 Views)
