IVI Driver for Hioki RM3544-01
I am looking to connect a Hioki RM3544-01 to my LabView SignalExpress software.  For other equipment I have been able to do this by installing IVI drivers for the device, but I could not find anything for the RM3544-01.  Does anyone have a driver or know how to make one?
Chris
(5,281 Views)
You make an IVI driver with LabWindows/CVI. Do you have LabVIEW?
(5,274 Views)
Yes, I do.  How do I make an IVI driver?  I was able to get LabVIEW libraries from Hiroki that can connect the device to a VI, but I'm not sure how to transform that into an IVI driver.
Thanks for your help,
Chris
(5,271 Views)
Okay, I found a manual at http://www.ni.com/pdf/manuals/320684f.pdf and I'm planning on following the example about the Instrument Driver Development Wizard
(5,270 Views)
You simply cannot create an IVI driver with LabVIEW.
You can call a VI from se, can't you?
(5,267 Views)
Oh, yep, it looks like you can.  Thanks, I am going to try that out and see if it works.
Chris
(5,264 Views)
