06-12-2006 04:09 PM
06-13-2006 10:06 AM
Hello daoustb,
Are you working in a true DOS environment or are you running a DOS window under some version of Windows? In any event, there is a getting started manual that I think will help you.
I hope this helps, please let us know if you have more questions about this.
Angela
06-13-2006 01:07 PM
06-13-2006 01:10 PM
06-14-2006 02:40 AM
06-14-2006 08:10 AM
06-14-2006 01:20 PM
06-14-2006 04:10 PM
Hi again,
I am not able to open any web site with this link. My Internet Explorer tells me there is nothing there.
Also, you aksed me :
Why are you needing to set this system up now?
I don't understand your question, I think. I need this system to make voltammetry.
When was the last time you had a working system?
A year, a year and a half ago. We were working with the exact same potentiostat. My GPIB-PCIIA card was in another computer. When we recently rebuild this system a few weeks ago, we realized that the computer was dead. We had to change it. We loaded on this new computer our DOS voltammetric software M270, from PAR). And now, we are trying to make it work with the drivers. The drivers were already installed on this "old" computer that we used a year ago or so. That's why I don't know which drivers I should use and how to make it work.
If you have access to any newer hardware/OS, we can enable DOS support for that hardware and see if your program will run in that manner. The following KB talks about how to enable DOS support, but this will require a 488.2 interface.
I was not able to open this link. It told me that nothing was there.
Thanks again for your time.
06-14-2006 04:34 PM
