NI VISA
Hello. I hope this is the correct board.
I've this problem. I bought a Siglent SPD3303C (rebranded RS-components).
It is not recognised as IVI USB TEST and Measurement Device with Labview 2016 and NI-VISA 16.0 or later.
It works with LV2012 and NI-VISA 5.4.
The NI-VISA driver wizard returns this error.
I'd really appreciate every suggestion.
(3,822 Views)
Which error?
(3,806 Views)
Hello. Sorry here you are the screenshot.
(3,760 Views)
The instrument looks good, on the web page but the links to the spec and the manual are wrong.
What is the manual saying about programming. It looks like you have a communication interface, probably serial. But without manual I cannot offer more help.
I wouldn't use the driver wizard because that one works at USB command level where you probably need the serial line text commands.
If you post the manual or give a good link to a web page I try to look at it and maybe I can give you better advice.
greetings from the Netherlands
(3,754 Views)
