RE: VI to measure power with Agilent E4404B
Hi All,
I have developed a VI based on the Agilent ESA PSA series instrument driver library to measure power with the E4404B.
The process is straight forward and intends to replicate the following manual procedure:
  1. Preset
  2. Set Center frequency
  3. Measure > Channel Power
  4. Meas Setup > Avg Number > 100
  5. Set Integration BW(IBW)
  6. verifying Span = 1.5 * IBW
  7. Optimize ref level
  8. Read Channel power
The FW version on the Spectrum Analyzer is A.14.06 which is the latest and I am using the NI GPIB-USB HS to control the instrument.
I have two issues with this VI:
  1. Although using the instrument driver's "close", The Spectrum analyzer remains in the remote mode, how do I get it to go to local at the end of the VI?
  2. Another issue is that after taking the measurement (completing the averages)the instrument's screen freezes, where as I want it to go back to the normal mode so that I can keep monitoring my input signal i.e. same behavior as manual power measurement
Any ideas how I can correct these two?
Message 1 of 1
(3,499 Views)
