RS232 Low Voltage...
Windows Hyperterminal was a good Idea! It works perfectly, even with the NI card... So what does that means? I have some progress to do with Labview? What is different? I put exactly the same parameters: 9600bds  8bits  no parity    stop=2    Xon/Xoff... I did exactly the same in the Serial configuration with the "Instrument I/O assistant"... But it doesn't work.
Message 11 of 24
(2,424 Views)
I was focused on the low voltage. Like I said it's not good but it can work.
Did you set the termination character as it shoul like The Kid said.
Can you post the (basic) VI ?
Message 12 of 24
(2,416 Views)
Yes sorry, I was sure it was because of the low voltage (witch is still strange for me but..).
But I am not using yet a VI because i wanted to try the connection before. So I use the "Instrument I/O Assistant" in the bloc diagram of an empty VI. Then I set up all the parameters (speed, termination character...) and I try to send a command in the serial toolbox. But nothing... Just the famous "?" sometimes...
In the hyperterminal, no problem, after all the commands I receive the good answer. I don't understand what can be THE difference in the Labview assistant...
Message 13 of 24
(2,414 Views)
It's OK, the low voltage is still a problem even if it is working. it will get back to you tomorrow, next month, next year Smiley Surprised
You said: 'So I use the "Instrument I/O Assistant" in the bloc diagram ' to be honest I don't know this assistant never used it.  Smiley Tongue
I can make you a basic COM VI which you can use to test your device communication.
Message 14 of 24
(2,412 Views)
If you have the time, yes you can make a VI. But I also tried a very basic one from this website (but not able to find it again...) and I had the same problem... But I will wait for your VI and will see...
Thank you again!
Message 15 of 24
(2,412 Views)
OK, maybe later this evening or otherwise tomorrow morning (for me) I don't know where you are located ?
Message 16 of 24
(2,408 Views)
I used a VI from a other RS232 thread.
This VI was ment to be used in a program. The configure and close should be at the beginning and end of a bigger program.
For the test I put the configure in front of this VI and forgetting the close Smiley Wink
Default settings: Time-out is set 10 sec. and there is a <cr> added to the input string. You can change both.
Fill in your COM parameters if they are not correct.
Have a try and just ask if it's not working or something is not clear.
Message 17 of 24
(2,403 Views)
OK it is working... But what is this <cr> that you added? What is it for? Is it a kind of start message?
And for the low voltage: I didn't find any electrical specifications about my NI board... So Does anybody know if that's normal or if I have to change it, or to activate a power somewhere in the computer?
@KC: Thank you again very much for your help. I don't know why this "Instrument assistant" is not working, but your VI looks good.
Message 18 of 24
(2,393 Views)
The <cr> is a ascii 'Carriage return' with most ascii commands you need to add this at the end of your command to a device to indicate the end of a command. The VI does this for you if you set the boolean input to (the default value) true
According to the spec. the PCI8430/8 only needs +5VDC for supply.
Message 19 of 24
(2,388 Views)
The transceivers used on this serial board are designed to output at +/- 5V.  This meets the requirement of the RS-232 specification, and should not cause any trouble communicating with your device.
I am glad to hear that you have solved the problem communicating with your instrument.  I just wanted to clarify that the voltage levels you are seeing are normal and expected for this board.
Jason Smith
Message 20 of 24
(2,377 Views)
