01-06-2015 01:02 AM
I've recently acquired a Scanivalve DSA 3217 / 16 Px system. I am trying to set this up with my PC and has directly connected the Scanivalve to the PC using a cross over ethernet cable. I am using the given softwave, which is the NI Labview as well as the DSA Labview 2009 Utility. However, I am unable to communicate to the Scanivalve using the TCP/IP address.
Help is much appreciated as I am running a project on this.
Thank you all!
Kai
01-06-2015 09:05 AM
02-23-2016 07:09 PM
You may need the drivers from scanivalve.
Did they send you the VIs too with DSA3217.
regards.
06-27-2017 01:54 PM
Hello Yakai, were you able to get this issue resolved? If not, email techsupport@scanivalve.com and Aaron, one of their engineers, will help you out.
