Sensors of Humidity compatible with Labview ??
Hello Blue,
thanks for the information.
Unfortunately, I do not know HygroLab, and cannot say so whether there are differences with the protocol.
-Frank
Message 21 of 25
(2,273 Views)
I too get the same error when trying to init the testo350 device from LabVIEW. Even in my case it works fine with Comfort3 software. How did you solve this problem?
Priyadarsini
Message 22 of 25
(1,902 Views)
I have the same problem, I want to read a digital barometric sensor, but i think that my board the PCI-6014 and a CB-68LP don't read digital .....
SEMOU 95 for example,  i am using a analog humidity sensor http://www.sparkfun.com/commerce/product_info.php?products_id=9569 and works very well
Somebody have code for this board to read a digital sensor ???
Thank You
Message 23 of 25
(1,766 Views)
If you are having problems reading a sensor, post a link to that instead of a link to something you do have working.
Message 24 of 25
(1,753 Views)
Finally after bouncing around in the forum, I get the final VI, I think that the Comfort3 software is very restrictive because only allow you to get the data and use it after saving. The only good thing is the DLL  Library that Testo provide in the toolbox.
After I made this VI I start using the testo input in a formula node and it save me a lot of work.
Message 25 of 25
(1,544 Views)
